CAD tip # 6950:
| Question | CAD % platform category |
applies to: AutoCAD 2010 · AutoCAD 2008 · AutoCAD 2005 · AutoCAD Map · AutoCAD Architecture · AutoCAD LT · | |||||||||
| See also: | |
| Tip 7249: | How to select all drawing entities containing a given text? |
| Tip 7003: | Modified drawing name as an automatic field. |
| Tip 6795: | FieldLink to display links between fields and objects. |
| Tip 6644: | Displaying layout name in dynamic text fields. |
| Tip 6559: | Arithmetic expressions in AutoCAD dimensions. |
Cannot select a specific text in my drawing.
Can I legally use a second copy of AutoCAD on my other PC? « | » How to run AutoCAD without opening an empty drawing?
Have we helped you? If you want to support the CAD Forum web service, consider buying one of our CAD applications, or our custom software development offerings.
Featuring: Simply link AutoCAD LT blocks to Excel table data. Excellink LT 2006
XANADU (CAD Studio) is not responsible for possible problems that may occur as a result of using any of these tips.
![CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz] CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]](../common/3d_x_t.gif)
Homepage
CAD Discussion
Tips & Tricks
Downloads
CAD Blocks
CAD Videos
Web Links
SW Development
