CAD tip CAD tip # 6947:
Question
If you want to run your AutoCAD without creating an empty "unnamed" drawing "Drawing1.dwg" (Zeichnung1.dwg, etc.), you can use a simple script to avoid it.
In the properties of the AutoCAD icon on your desktop edit the line Target and add a parameter:
/b close
e.g.:
"C:\Program Files\AutoCAD 2010\acad.exe" /b close
Now create a simple text file CLOSE.SCR in AutoCAD search path (so it can find it) - this file will containg a single line (ended with Enter):
_CLOSE
If you start AutoCAD using this icon, the empty DWG drawing will be immediately closed.
Another option is the variable STARTUP.
ACAD
18.9.2009   19014×
this tip shared by ARKANCE experts applies to: AutoCAD ·
Tip 15102:DBXscan/DBXrem batch utilities for AutoCAD
Tip 15094:Adding nearby points as additional vertices of a polyline - AddPolyPts.
Tip 15090:3DPlot - 3D math surfaces in AutoCAD.
Tip 15089:2DPlot - parametric math curves in AutoCAD.
Tip 15080:How to replace internal blocks with external blocks (XREFs) in AutoCAD LT?
Back    All CAD Tips
Categ:
