CAD tip CAD tip # 9665:
Question
Using the commands TABLE resp. DATALINK you can insert a live content of Excel tables (or parts of them) to your AutoCAD drawing. On any subsequent change of the Excel table you will be notified by AutoCAD and you will have to update the DWG content manually (updates do not depend on the DXEVAL variable).
If you want to perform the update of Excel table data automatically, after you open your DWG drawing, you can use a simple LISP function. Find the file ACADDOC.LSP (by default in the local user Support folder) and add the following line using Notepad.exe:
(command "_DATALINKUPDATE" "_U" "_K")
If the file ACADDOC.LSP does not exist, create it.
Now after you open any drawing, its data links will be automatically updated.
ACADADTACADMCivilMapPlant
27.1.2014   17502×
this tip shared by ARKANCE experts applies to: ACAD · ADT · ACADM · Civil · Map · Plant ·
Tip 14998:What is the difference between two open documents, two open Inventors, and two Inventors on two different PCs?
Tip 14986:How to launch Autodesk Fusion online, in a web browser?
Tip 14799:7 quick methods to upload your project to Autodesk Docs (Forma Data Management)
Tip 14746:Connecting nearby points in a point field by lines.
Tip 14620:Converting object data (OD) to XData (XD) in AutoCAD Map 3D.
Back    All CAD Tips
Categ:
