CAD tip CAD tip # 8686:
Question
When trying to connect and login to the online service Autodesk 360 from AutoCAD or Inventor you may get an error - requested service is temporarily unavailable and the connection fails (it works fine when executed directly in your web browser).
The problem may be in your internet browser. The Autodesk 360 connection requires Internet Explorer. If you use an alternative browser, your Internet Explorer was probably not yet started and so it is not configured. Its configuration is done automatically on the first launch. After the configuration of MSIE you will be able to connect to Autodesk 360 from Inventor and AutoCAD.
For Autodesk 360 synchronization problems (system tray icon) use the Autodesk Sync 2013 SP1.
ACAD2013ACLT2013Inv2013Revit2013
12.6.2012   19965×
this tip shared by ARKANCE experts applies to: AutoCAD 2013 · AutoCAD LT 2013 · Inventor 2013 · Revit 2013 ·
Tip 15091:Autodesk Assistant in Inventor: AI-powered automation for model states
Tip 15040:Autodesk Flex Token Calculator - "Pay-as-you-go" pricing for licenses and services.
Tip 14555:How to disable or expire a public link to my Fusion design?
Tip 14507:Fixed Workpoints (X,Y,Z) in Autodesk Inventor.
Tip 13944:Intersection of a 3D spline with a plane in Fusion 360.
Back    All CAD Tips
Categ:
