CAD tip CAD tip # 7238:
Question
Suddenly you are not able to edit drawing geometry by doubleclick (displays only grips), nor edit text (it is only highlighted)- but the DBLCLKEDIT variable is set properly to 1 (On).
The double-click functionality depends also on one more variable - PICKFIRST. Make sure it is set to 1. In older versions of AutoCAD (older Express Tools) also check the other (now obsolete) double-click handler - the function DCPROPS.
ACADACLTADT
26.2.2010   23535×   FAQ
this tip shared by ARKANCE experts applies to: ACAD · ACLT · ADT ·
Tip 3498:Double-click edit works only on some PCs.
Tip 1790:How to edit all types of entities using a single command?
Back    All CAD Tips
Categ:
