CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 2014
CAD tip CAD tip # 7354:
Maximum number of tips per one unauthorized session has been reached.
You can gain an unlimited access on CAD Studio's VIP-server.
Tip 8460:Unusual AutoCAD linetypes - from Microstation RSC files.
Tip 8396:Ray hatch patterns in AutoCAD.
Tip 8177:How to convert an existing hatch to associative?
Tip 8172:I have multiple copies of AutoCAD definition files. Which one will be loaded?
Tip 7916:Searching for hatches with missing Area property.
How to set a LISP variable in AutoCAD? « | » Batch convert DWG drawings to an older file format.
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
