CAD tip CAD tip # 7347:
Question
You can convert multiple drawing files in the .DWG format to an older version of this CAD format (for older versions of AutoCAD or LT) with a free Windows utility Autodesk DWG TrueView (former "DWG TrueConvert"). TrueView offers bidirectional file conversion and batch conversion between the AutoCAD DWG formats of R14, 2000, 2000i, 2002, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011 (older versions of TrueConvert support saving back also to V2.x, R9, R10, R11, R12, R13 DWG format files). This DWG converter and viewer is available in both 32-bit and 64-bit versions.
Starting and setting conversion parameters in DWG TrueView:
Batch conversion of DWG formats
This application is free for download on DL Download.
ACADDWG
6.5.2010   49091×
this tip shared by ARKANCE experts applies to: AutoCAD · DWG ·
Tip 14333:A free tool for bulk-purging of DWG drawing files.
Tip 13274:How to switch the DWG TrueView viewer to the classic user interface, without ribbon?
Tip 12325:How to display a DWG from Advance Steel including AS objects? (AST viewer)
Tip 12103:Random lines are displayed over my AutoCAD drawing.
Tip 12049:AutoCAD display (status bar) jumps and flickers while zooming.
Back    All CAD Tips
Categ:
