Over 1.124.000 registered users (EN+CZ).
CAD tip # 7741:
Question
AutoCAD Mechanical allows to set "mechanical structure" for its drawings (grouping components and assemblies). This option is available in the Options dialog, the tab AM:Structure - "Enable structure for new drawings".
IF you want to set this option from a script or a macro, use the LISP command (to disable or to enable):
(gencfgset "gen@CIT@Enable Structure" 0) (gencfgset "gen@CIT@Enable Structure" 1)
ACADM2011ACADM2010ACADM2009
19.1.2011
12910×
this tip shared by ARKANCE experts applies to: AutoCAD Mechanical 2011 · AutoCAD Mechanical 2010 · AutoCAD Mechanical 2009 ·
