CAD tip CAD tip # 11776:
Question
AutoCAD LT by default offers only attribute and coordinate export of block references - after you prepare a special template for the ATTEXT command.
But with the function "Report Coordinates" in the bonus add-on application CADstudio LT Extension you can export XYZ coordinates of any selected DWG objects. The coordinates are written to a text file with comma-delimited values (CSV). Similarly you can batch export texts, line lengths and other data from your drawings.
See video:
See LT Extension
ACLT
26.1.2018   24546×
this tip shared by ARKANCE experts applies to: AutoCAD LT ·
Tip 15040:Autodesk Flex Token Calculator - "Pay-as-you-go" pricing for licenses and services.
Tip 14861:RegExpCnt - LISP string replace function with arithmetic/counter-extension
Tip 14833:CAD formats supported in Autodesk VRED 2026.
Tip 14053:Why doesn't my export from Civil 3D to IFC 4.3 export surfaces and solids?
Tip 13833:Overview of cutting formats/machines supported in Fusion 360 Nesting Extension.
Back    All CAD Tips
Categ:
