CAD tip CAD tip # 8104:
Question
The project coordination and management application Autodesk Navisworks 2012 directly supports reading 3D CAD data in the following file formats:
NW formats
  • Navisworks (nwd, nwf, nwc)
  • 3D Studio (3ds, prj)
  • AutoCAD - Autodesk RealDWG (dwg, dxf)
  • PDS Design Review (dri)
  • ASCII laser (asc, txt)
  • Microstation Design File (dgn, prp, prw)
  • DWF (dwf, dwfx, w2d)
  • FBX (fbx)
  • IGES (igs, iges)
  • Inventor (ipt, iam, ipj)
  • Leica (pts, ptx)
  • Pro/Engineer (prt, asm, g, neu)
  • PDMS RVM (rvm)
  • STEP (stp, step)
  • STL (stl)
  • SAT-ACIS (sat)
  • CIS/2 (stp)
  • IFC (ifc)
  • Faro (fls, fws, iQscan, iQmod, iQwsp)
  • Informatix MAN (man, cv7)
  • JTOpen (jt)
  • Parasolid Binary (x_b)
  • Riegl (3dd)
  • SketchUp (skp)
  • VRML (wrl, wrl)
  • Z+F (zfc, zfs)
See a detailed description of supported formats (PDF, 3.3MB)
NW2012
25.7.2011   12012×
this tip shared by ARKANCE experts applies to: Navisworks 2012 ·
Tip 15045:Which cloud projects are available in the Autodesk Forma mobile app?
Tip 15040:Autodesk Flex Token Calculator - "Pay-as-you-go" pricing for licenses and services.
Tip 14957:Controlling Navisworks from the runstring.
Tip 14799:7 quick methods to upload your project to Autodesk Docs (Forma Data Management)
Tip 14705:What is the difference between Data Exchange Connector and import/export support for a given CAD/BIM format?
Back    All CAD Tips
Categ:
