Over 1.118.000 registered users (EN+CZ).
CAD tip # 10266:
Question
The property called "Standard" is a standard iProperty. But it is not accessible through the Properties dialog. If you need to edit it directly, you can use the following VBA macro:
Sub SetStandard()
Dim oProp As Inventor.Property
Set oProp = ThisApplication.ActiveDocument.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")("Standard")
oProp.Value = InputBox("Enter the value of the new standard", , oProp.Value)
End Sub
Copy this code to your Inventor VBA project and run the macro. A window with the current value of the Standard of the active document will be displayed; overwrite it and click OK to update the value in the document.
Inventor
31.3.2015
13890×
this tip shared by ARKANCE experts applies to: Inventor ·
