Over 1.127.000 registered users (EN+CZ).
CAD tip # 8487:
Question
If you need to change the display style (color) of RPC trees in your Revit scene - displaying in a shaded view, not in render - you can use the settings for the Planting objects.
In the ribbon Manage > Settings > Object Styles go to the "Planting" objects and in the "Material" column (empty) click on the material browser. Choose an appropriate material (e.g. terrain-grass) or create a new one. The color of trees in a shaded or realistic view will change from the default gray color.
Revit2012
24.2.2012
23718×
this tip shared by ARKANCE experts applies to: Revit 2012 ·
