CAD tip CAD tip # 9104:
Question
Conversion of 3D models from Revit projects and families (.RVT, .RFA) to the neutral CAD format STEP is currently (versions <=2013) not possible to perform in a single step - you need two conversions.
First save the model in Autodesk Revit to the SAT format (ACIS) and then convert this file using e.g. the free application Inventor Fusion (also included in AutoCAD) to a file in the STEP format (or IGES, Parasolid/.x_t, Inventor/.ipt, CATIA/.CATpart, etc.).
RevitACADInventor
20.2.2013   73840×
this tip shared by ARKANCE experts applies to: Revit · AutoCAD · Inventor ·
Tip 15040:Autodesk Flex Token Calculator - "Pay-as-you-go" pricing for licenses and services.
Tip 14869:How to generate a Regression curve through a set of points in AutoCAD or other CAD?
Tip 14864:How to generate a spirograph curve, guilloche, for CAD applications?
Tip 14705:What is the difference between Data Exchange Connector and import/export support for a given CAD/BIM format?
Tip 14681:How to quickly convert XLS tables to CSV format without opening Excel?
Back    All CAD Tips
Categ:
