CAD tip CAD tip # 6898:
Question
How to make a symmetrical drawing where the left side is always (even after editing) a perfect mirror of the right side?
In AutoCAD, you can use Xref for this. First make a drawing consisting of the right half only and save it.
Then make a new empty drawing and attach this right part as a Xref (scale 1:1). Then attach the same part again as a Xref, this time with the X-scale set to -1. Align both halves together.
Any changes in the left or right part (done by RefEdit/doubleclick or by editing the separate DWG) will be reflected in the other part.
Possible texts will be displayed mirrored
ACADACLT
31.8.2009   15236×
this tip shared by ARKANCE experts applies to: ACAD · ACLT ·
Tip 15155:How to collaborate on DWG files simultaneously (multiplayer mode, concurrent editing)?
Tip 15102:DBXscan/DBXrem batch utilities for AutoCAD
Tip 15080:How to replace internal blocks with external blocks (XREFs) in AutoCAD LT?
Tip 15042:When you try to change the viewport annotation scale, the error "XRef lock" appears.
Tip 15017:AutoCAD Drawing Cleanup Utility - a standalone tool to purge your DWG files.
Back    All CAD Tips
Categ:
