CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 2381
CAD tip CAD tip # 6904:
Missing option "Include when adding sheets" in AutoCAD 2010?
A - answer If you have upgraded to AutoCAD 2010 from an older version (2009), you may miss the option "Include when adding sheets" (Model/Layout) in the dialog of the command PUBLISH.
The selection of model/layout tabs is now available directly in the file selection dialog when adding new sheets to publish. For existing sheets, you can control this setting in the context menu - after mouse right-click on the sheet name.
ACAD2010
3.9.2009    2165x
Comments   Tell a friend
applies to: AutoCAD 2010 ·
Tip 8425:Batch print for multiple drawings, multiple printers and copies.
Tip 7910:Publishing old Whip-DWF files from AutoCAD 2011.
Tip 7806:Selectable text in PDF files from AutoCAD.
Tip 7667:Automatically generated QR codes for DWG drawings.
Tip 7597:Quick conversion of DWG files to PDF.
The Separate option does not work on my combined 3D solids. « | » How to create an always symmetrical drawing?
Link your AutoCAD block attributes with Excel tables/sheets. Automatically. Dynamically. Bidirectionally.
Try Excellink 2012 More info
