CAD tip CAD tip # 9412:
Question
You can setup preview effects for object selection with the command OPTIONS - Options > Selection > Visual effects.
But if AutoCAD does not respond on switching off selection previews and selected objects are always displayed with thick lines, the problem is in the graphics driver. Try its behaviour when you switch off hardware acceleration (see the AutoCAD status bar icon).
ACAD2014ACAD2013ACAD2012
26.8.2013   17729×
this tip shared by ARKANCE experts applies to: AutoCAD 2014 · AutoCAD 2013 · AutoCAD 2012 ·
Tip 14894:Importing CSV points in Map/Civil - ImportPoints vs. MapImport.
Tip 14869:How to generate a Regression curve through a set of points in AutoCAD or other CAD?
Tip 14770:Volumetric textures in Autodesk Fusion.
Tip 14673:Extrude a raster image to a 3D mesh - e.g. for engraving in Fusion.
Tip 14172:How to change the design thumbnail image in Autodesk Fusion?
Back    All CAD Tips
Categ:
