Over 1.105.000 registered users (EN+CZ).
New AutoCAD 2026 commands and sys.variables and env.variables,.
CAD tip # 9418:
Question
If Inventor displays a modelling operation error message:
The attempted operation did not produce a meaningful result. Try with different inputs.
it is usually caused by invalid geometry - e.g. imported from external data. A frequent source of problems is e.g. an extrusion path as a curve containing duplicate vertices, duplicate segments or "zig-zag" (backing) segments along its length.
Inv
28.8.2013
14936×
this tip shared by ARKANCE experts applies to: Inventor ·
![CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz] CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz]](../common/arkance_186.png)
