Over 1.124.000 registered users (EN+CZ).
CAD tip # 8653:
Question
The Task Pane window can be permanently enabled or disabled by setting the Options in AutoCAD Map 3D.
Run the MAPOPTIONS command and check or uncheck the option "Show Task Pane On Startup" in the "Task Pane" tab (startup options). In the current session, you can switch the Task Pane on and off using the MAPWSPACE command.
In an undocked state you can also control the transparency of the Task Pane palette - right click on its title bar.
Map
28.5.2012
56404×
this tip shared by ARKANCE experts applies to: AutoCAD Map 3D ·
