CAD tip CAD tip # 10314:
Question
When entering or editing angle dimensions or in other cases of entering angles in Inventor, you can use not only decimal angles but also the angular format degrees - minutes - seconds (DMS) - e.g.:
60°30'30"
Use the characters (delimiters) "°" (circumflex), "'" (apostrophe) a """ (quotes, double-apostrophe).
angular units
Tip credit: R.Seris (cadman181)
Inventor
14.5.2015   10350×
this tip shared by ARKANCE experts applies to: Inventor ·
Tip 15138:AutoCAD Field formatting codes - full list.
Tip 10412:How to enter angles in survey units?
Tip 8365:Inventor understands many different measurement units.
Tip 7439:Extended FILLET functionality.
Tip 7329:Draw 3D polyline by length, azimuth, slope.
Back    All CAD Tips
Categ:
