CAD tip CAD tip # 9401:
Question
A successfully installed Service Pack 1 in aplikaci Autodesk Navisworks can be identified from the field "Version" in the dialog "About Autodesk Navisworks". This dialog can be displayd with the function "About Autodesk Navisworks 2014" in the menu under the question-mark icon in the application top bar.
The originally installed version has the version number 11.0.0.98373, after the installation of SP1 this version number changes to 11.4.0.101763 and the Built date to July.
Before ("SP0"):
After ("SP1"):
NW2014
20.8.2013   11964×
this tip shared by ARKANCE experts applies to: Navisworks 2014 ·
Tip 11863:You cannot install this product on the current operating system.
Tip 11854:iLogic error in Inventor 2019: invocation of constructor threw an exception
Tip 11082:Wrong license cascading on Inventor in Product Design Suite 2017.
Tip 10084:Error "Unsupported operating system" when installing Revit LT 2015.
Tip 9461:Cannot start my Inventor 2014 in OS Windows 8.1.
Back    All CAD Tips
Categ:
