CAD tip CAD tip # 7178:
Question
If you need to "hang" a picture or whiteboard, stick a poster in a window, create a switched-on TV set, or use another case of applying your texture on a face in a Revit project, you can use the "Decal" function.
The procedure of applying your custom raster image is described in the Revit video #29:
Revit2010
23.1.2010   29300×
this tip shared by ARKANCE experts applies to: Revit 2010 ·
Tip 14496:Convert scanned point clouds or photos to BIM objects - Scan-to-BIM.
Tip 14472:Overview of CAD formats supported in Inventor 2026 (import/export/AnyCAD).
Tip 14349:12 free material texture libraries for PBR rendering.
Tip 14281:Mapped network drives (S:, T:, X:, etc.) are not available in my CAD application.
Tip 14075:Overview of CAD formats supported in Inventor 2025 (import/export/AnyCAD).
Back    All CAD Tips
Categ:
