CAD tip CAD tip # 8384:
Question
If you want to join a 3D polyline with another one, or with a spline, you can use the command JOIN. This function joins also two or more 3D polylines into one, or joins a 3D polyline with a spline to a new spline curve.
You can use JOIN for 3D lines (geometry) also in AutoCAD LT.
ACAD2012ACLT2012
2.1.2012   36490×
this tip shared by ARKANCE experts applies to: AutoCAD 2012 · AutoCAD LT 2012 ·
Tip 14962:How do you connect two offset lines with an ogee curve, double-arc wave?
Tip 11769:How to convert border lines (rails) to a surface?
Tip 8269:Connecting polylines by fillet - change in version 2012.
Tip 7998:How to change a straight polyline segment to arc segment?
Tip 5673:How to convert a 3DPOLYLINE to a 2DPOLYLINE (LWPOLYLINE)?
Back    All CAD Tips
Categ:
