CAD tip CAD tip # 7297:
Question
One of the new powerful 3D functions in AutoCAD 2011 (and higher) is the PROJECTGEOMETRY command, which can project - drape - any curve, polyline, line or point to any 3D surface.
You can specify the project direction by the current view, by the direction vector, or by UCS. The projected geometry is displayed (as splines) on the selected 3D solid or surface body (incl. NURBS surfaces).
You can use this command e.g. to project texts (TXTEXP exploded) to free surface meshes.
Text projected to NURBS surface
For projecting to a sphere use the SphereProj utility.
ACAD2013ACAD2012ACAD2011ADT2011Civil2011
7.4.2010   52502×
this tip shared by ARKANCE experts applies to: AutoCAD 2013 · AutoCAD 2012 · AutoCAD 2011 · AutoCAD Architecture 2011 · Civil 3D 2011 ·
Tip 15102:DBXscan/DBXrem batch utilities for AutoCAD
Tip 15070:Parametric labeling/numbering in AutoCAD Electrical.
Tip 15063:How do I convert the geometry of a Civil pipe network to 2D, or to SHP format?
Tip 15040:Autodesk Flex Token Calculator - "Pay-as-you-go" pricing for licenses and services.
Tip 14911:Using symbolic variables to enter repeated values in AutoCAD.
Back    All CAD Tips
Categ:
