CAD tip CAD tip # 7305:
Question
A single command RECTANGLE in AutoCAD 2011 (and higher) can create two different types of rectangle objects - displaying differently and first of all behaving differently.
Two different rectangles in AutoCAD
This behaviour is driven by the variable controlling the automatic inferring of geometric constraints - CONSTRAINTINFER, resp. by the switch "Infer constraints" (the leftmost icon on AutoCAD status line). The constraint icons display depends on the CONSTRAINTBARMODE variable - disabling the constraint bar can make the rectangles look the same. There will be differencies in grip-editing of such rectangles.
See also the tip 6832.
ACAD2011ADT2011ACADM2011Civil2011
12.4.2010   15048×
this tip shared by ARKANCE experts applies to: AutoCAD 2011 · AutoCAD Architecture 2011 · AutoCAD Mechanical 2011 · Civil 3D 2011 ·
Tip 14509:AutoCAD linetypes - the A/R/U orientation options in complex text-linetypes.
Tip 14088:3 methods of creating true rectangles in AutoCAD.
Tip 14033:Clipping blocks, images, curves, xrefs - everything, into any shape
Tip 13843:Accented characters (umlauts) are incorrectly displayed in the material schedule on isometric drawing.
Tip 13163:Blended transitional solid between irregular regions, circle-rectangle transition (3D in AutoCAD)
Back    All CAD Tips
Categ:
