CAD tip CAD tip # 9324:
Question
Some add-on applications may create a large number of anonymous groups in a DWG file while copying objects. These anonymous groups (blocks) are named like *A1, *A2, .... *A####. They cannot be erased with standard AutoCAD tools.
To delete and remove these groups, use the freeware utility by CAD Studio - DelGrpA. Download the LSP file from DL Download, load it with APPLOAD and run the DELGRPA command. This command lists all deleted anonymous groups.
ACADADTCivilACADM
6.7.2013   23441×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD Architecture · Civil 3D · AutoCAD Mechanical ·
Tip 11751:toMulti converts polylines to multi-lines driven by a definition table.
Tip 6248:Cannot ungroup an object group created in AutoCAD LT.
Tip 6210:Various types of anonymous blocks in AutoCAD.
Back    All CAD Tips
Categ:
Take advantage of orthophotos, point clouds, and design files. Get better quality design changes faster with Pointscene More info
