CAD tip CAD tip # 6718:
Question
You can use the QSELECT or FILTER commands to select all blocks with a given name.
But there is also a quicker way - you can use a simple macro which selects all blocks of the same name as a picked block (block reference, Insert). The SELBLK.LSP macro can be found on DL Download.
Load the LSP file with APPLOAD and then anywhere AutoCAD prompts to "Select objects" just type 'SELBLK (or 'SELBLKS for multiple block names, or 'SELBLKN for typed block names, wildcards).
ACADADTACADMCivil
2.6.2009   41721×
this tip shared by ARKANCE experts applies to: ACAD · ADT · ACADM · Civil ·
Tip 15129:Failure to open a CAD file from OneDrive (AutoCAD, Revit, Inventor...)
Tip 15094:Adding nearby points as additional vertices of a polyline - AddPolyPts.
Tip 15089:2DPlot - parametric math curves in AutoCAD.
Tip 14991:Changing the order of rows in a table - sorting tables in AutoCAD.
Tip 14889:Unfolding of general polygonal 3D meshes (mesh unfolder).
Back    All CAD Tips
Categ:
