CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 458
CAD tip CAD tip # 7249:
Maximum number of tips per one unauthorized session has been reached.
You can gain an unlimited access on CAD Studio's VIP-server.
Tip 7892:How to find blocks with an empty (not-filled-in) attribute?
Tip 7241:Searching text in DWG drawings (without AutoCAD).
Tip 6947:How to run AutoCAD without opening an empty drawing?
Tip 4708:How to find a dot (.), asterisk (*) or question mark (?) in the drawing text?
Tip 3714:How to replace only a single occurrence of a substring in a drawing text?
How to import CEL files (Microstation blocks) into AutoCAD? « | » How to load/install a LISP application in AutoCAD?
Make your drawings dynamic - change text, attribute or color when other entity changes.
With LiveLabel 2007 More info
