CAD tip CAD tip # 9026:
Question
Precision (number of decimal places) of coordinates exported in point files from AutoCAD Civil 3D can be set in the settings of the given format.
In the toolspace on the Settings tab, choose Point and in "Point file formats" choose the requested format, e.g. PXYZ. Right-click on it and choose Properties from the context menu - this will launch the "Point file format" dialog. In this dialog, click on the header of the X and Y columns (or others) and set the Precision field.
Civil
14.1.2013   86870×
this tip shared by ARKANCE experts applies to: Civil 3D ·
Tip 14526:How to export geometry from AutoCAD DWGs to JSON files and import it back?
Tip 14351:How to suppress trailing zeros in Inventor parts list?
Tip 13692:What is the precision in Revit?
Tip 13006:Calculated property descriptions (tobogan slide from floor to floor)
Tip 12766:Lines with a single grip, incorrect osnaps, intersections, offsets, hatches - CheckLarge
Back    All CAD Tips
Categ:
