Over 1.127.000 registered users (EN+CZ).
CAD tip # 8458:
Question
If you need to change (preset) the default selection mode for the HATCH command - not by picking a point but by selection of the border objects - you can do this by changing the command icon in the ribbon.
Use the CUI dialog to change the hatch icon/command to call _HATCH _Sel instead of the default _HATCH. So the new format of the command will read:
^C^C_hatch _sel
ACAD2012ACAD2011ACLT
9.2.2012
20221×
