CAD tip # 6933:
| Question | CAD % platform category |
applies to: AutoCAD · | |||||||||
| See also: | |
| Tip 7249: | How to select all drawing entities containing a given text? |
| Tip 7241: | Searching text in DWG drawings (without AutoCAD). |
| Tip 7219: | Aligning drawings to multiple points (4, 5, 6 ...) |
| Tip 7216: | How to use 3DFACEs as a definition for terrain surface? |
| Tip 7164: | The NLS files required to convert the text entities... |
Framed text in leader dimensions.
Missing constraint "perpendicular" in 2D sketch. « | » How to restore Inventor browser?
Have we helped you? If you want to support the CAD Forum web service, consider buying one of our CAD applications, or our custom software development offerings.
Featuring: Add .CIT raster format support to AutoCAD and Map and Civil 3D CITin
XANADU (CAD Studio) is not responsible for possible problems that may occur as a result of using any of these tips.
![CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz] CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]](../common/3d_x_t.gif)
Homepage
CAD Discussion
Tips & Tricks
Downloads
CAD Blocks
CAD Videos
Web Links
SW Development
