CAD tip CAD tip # 7859:
Question
If you need to split your multi-sheet drawing in Inventor into the individual separate single-sheet drawings, you can use the VBA macro CADstudio SplitDrawing.
Load the file (project) SplitDrawing.ivb in the Inventor VBA Editor (Load project) and then in the ribbon Tools > Options > Macros run the macro "Module1.SplitDrawing".
SplitDrawing splits the current drawing document into the individual drawings named as the pattern (example): MyDrawing_Sheet1_MyModelA.idw, MyDrawing_Sheet2_MyModelB.idw, etc.
SplitDrawing can be downloaded from DL Download
You can also use the iLogic rule SplitDrawing available on CAD Studio's Helpdesk.
See also the Multi-Sheet Plot utility (on Download)
Invenrtor2012Inventor2010
15.3.2011   15961×
this tip shared by ARKANCE experts applies to: Invenrtor2012 · Inventor 2010 ·
Tip 15102:DBXscan/DBXrem batch utilities for AutoCAD
Tip 14359:Automatic macro execution when opening a CAD file (AutoCAD, Inventor, Max, PowerMill)
Tip 12828:How to quickly delete 3rd party links to external objects in Inventor?
Tip 12815:How to fill iProperties into Inventor files from Excel?
Tip 12520:How to set Inventor Display style and Lighting style from an iLogic macro?
Back    All CAD Tips
Categ:
