CAD tip CAD tip # 7812:
Question
The AutoLISP functions (write-line) and (write-char) automatically add the full CR/LF sequence (carriage return, line feed) when trying to output just the LF (line-feed, chr 10).
There is a trick of forcing AutoCAD to output really just the line-feed. Use the (write-char) function and add 256 to the character code. So instead of (write-char 10 f), use (write-char 266 f). An example:
(setq f (open "C:/TEMP/TESTFILE.TXT" "w"))
(write-char 266 f)
(close f)
writes a file testfile.txt containing just the LF character.
ACAD2011
23.2.2011   19698×
this tip shared by ARKANCE experts applies to: AutoCAD 2011 ·
Tip 15089:2DPlot - parametric math curves in AutoCAD.
Tip 14991:Changing the order of rows in a table - sorting tables in AutoCAD.
Tip 14911:Using symbolic variables to enter repeated values in AutoCAD.
Tip 14889:Unfolding of general polygonal 3D meshes (mesh unfolder).
Tip 14618:Easy copying of DWG entities with rotation.
Back    All CAD Tips
Categ:
