CAD tip CAD tip # 8496:
Question
With the enhanced version of the free LISP utility ASCPOINT - see DL Download - you can import CDF/SDF text files into 2D or 3D points, polylines and block references.
The ASCPOINT command reads selected file (comma- or space-delimited, e.g. from Excel, CSV) and inserts points, vertices or blocks on the specified coordinates. The option "Insert" allows to select a predefined block with any number of attributes. The input file can then contain the values of these attributes which will be filled in on import - e.g.:
12.3 4.56 7.8 MyAtt1 MyAtt2
For a single label you can use e.g. the block AttPoint (download and insert the DWG) and an input file in the format:
X,Y,Z,Label
Sample video:
ACAD
28.2.2012   84845×
this tip shared by ARKANCE experts applies to: ACAD ·
Tip 15090:3DPlot - 3D math surfaces in AutoCAD.
Tip 15089:2DPlot - parametric math curves in AutoCAD.
Tip 14894:Importing CSV points in Map/Civil - ImportPoints vs. MapImport.
Tip 14630:Extended ASCPOINT - import coordinates from CSV file, including blocks with attributes, GPS coordinates, etc.
Tip 14093:3D terrain model of any place in Czechia - elevation data by the Czech Land Survey Office (CUZK) into Civil 3D.
Back    All CAD Tips
Categ:
