CAD tip CAD tip # 8657:
Question
When trying to import a list of point coordinates from a TXT file to AutoCAD Civil 3D, an error message is displayed: "No point file format match found"
Import - error (CZ)
The coordinate text file is most probably saved in Unicode (16-bit). The point import function requires a standard 8-bit ANSI encoding. So just open and re-save your file in Notepad to the ANSI format:
ANSI - Notepad (CZ version)
And retry the import.
Civil
29.5.2012   20171×
this tip shared by ARKANCE experts applies to: Civil 3D ·
Tip 14894:Importing CSV points in Map/Civil - ImportPoints vs. MapImport.
Tip 14808:How to import a KML/KMZ file from Google Maps, including placemark labels, into AutoCAD Map 3D?
Tip 14630:Extended ASCPOINT - import coordinates from CSV file, including blocks with attributes, GPS coordinates, etc.
Tip 14620:Converting object data (OD) to XData (XD) in AutoCAD Map 3D.
Tip 14598:Thread machining in Autodesk Fusion.
Back    All CAD Tips
Categ:
