CAD tip CAD tip # 8506:
Question
When sectioning a part through a rib, hatching is applied also to the rib in the section view. How to avoid the rib hatch?
If the rib is a separate part in an assembly, you can suppress its hatching with the Visibility setting in the view (right mouse click) or via the filters.
If the rib is only a feature in a part, you can suppress the hatching only by doing some changes:
  • either use a multibody part and disable the drawing view hatching via the body filter
  • or select the hatch, turn it off (right mouse button) and use the Project Geometry to draw edges for a new, manual hatching
Inventor2012Inventor2011Inventor2010
2.3.2012   15850×
this tip shared by ARKANCE experts applies to: Inventor 2012 · Inventor 2011 · Inventor 2010 ·
Tip 14953:Importing ECLASS files into AutoCAD Electrical.
Tip 14869:How to generate a Regression curve through a set of points in AutoCAD or other CAD?
Tip 14838:How to create a diameter/radius dimension with a horizontal leader in Inventor?
Tip 14673:Extrude a raster image to a 3D mesh - e.g. for engraving in Fusion.
Tip 14634:Physical units conversion tool in an Inventor palette.
Back    All CAD Tips
Categ:
