CAD tip CAD tip # 8503:
Question
Displaying special icons for DWG files with valid digital signatures can make Windows Explorer slow.
You may want to disable this setting. Right-click on the AutoCAD icon (on your desktop) and choose "Enable/Disable Digital Signature Icons". Uncheck the Validate option and restart (login) your Windows session.
You can also do the same by starting the AcSignOpt.exe program from the Windows System folder (\Windows\Sysnative in 64-bit versions).
ACADACLT
1.3.2012   27970×
this tip shared by ARKANCE experts applies to: ACAD · ACLT ·
Tip 11953:How to save PDF/A-1a archive from CAD software AutoCAD, Inventor, Revit?
Tip 10258:Digital signature of CAD files in the DWFx format.
Tip 8673:Cannot sign DWG drawing - error: "A digital ID is required"
Tip 3171:How to add other time sources for digital IDs (signatures)?
Tip 2892:How do I find whether a drawing is digitally signed?
Back    All CAD Tips
Categ:
