CAD tip CAD tip # 9630:
Question
Even without iLogic you can use a math trick in Inventor to set a parameter value based on a logical condition, depending on the value of another parameter.
Strictly speaking it is not about a logical condition, but rather about testing of divisibility by two, using the standard arithmetic operator modulo (%):
The expression:
v%2
returns 1 for odd values of v
and the expression:
(v+1)%2
returns 1 for even values of the parameter v.
By combining these two expressions you can form a "logical" conditional statement, which evaluates to H1 for odd values of v and to H2 for even values of v:
(v%2)*H1+((v+1)%2)*H2
Analogically you can extend this method also for other values but the resulting expression may get complicated fast.
Inventor
8.1.2014   17146×
this tip shared by ARKANCE experts applies to: Inventor ·
Tip 15091:Autodesk Assistant in Inventor: AI-powered automation for model states
Tip 15090:3DPlot - 3D math surfaces in AutoCAD.
Tip 15089:2DPlot - parametric math curves in AutoCAD.
Tip 14569:The extent of the sheetmetal unfold rounded to integer numbers.
Tip 14560:JobTime for Autodesk Fusion - tracking time spent on a job.
Back    All CAD Tips
Categ:
