CAD tip CAD tip # 10790:
Question
A text in Inventor, created dynamically, from the value of a design parameter or property (e.g. a text in a title block) can be wrapped automatically into two or more lines if it doesn't fit into the given window (its width).
For such line-wrap, two conditions must be met. The text must contain spaces, on which the wrapping appears, and you must not force the single-line display for this text. The option "Single line text" can be set with the button between the fields "% Stretch" and "Spacing":
Inventor
12.3.2016   6654×
this tip shared by ARKANCE experts applies to: Inventor ·
Tip 14641:Automatic naming of Inventor drawing sheets according to the first model (iLogic).
Tip 14611:Contribution of individual features to the total mass of an Inventor part (iLogic).
Tip 14527:Search/Replace texts in Inventor drawings - iLogic.
Tip 14526:How to export geometry from AutoCAD DWGs to JSON files and import it back?
Tip 13426:Use of alternative units for arithmetic in dimensions (without square brackets).
Back    All CAD Tips
Categ:
