Over 1.127.000 registered users (EN+CZ).
CAD tip # 8608:
Question
When mirroring Inventor assemblies, standard parts inserted from Content Center and factory parts are mirrored with "reuse" by default. If you want to mirror them the same way as usual components, uncheck (clear) the option "Reuse Standard Content and Factory Parts" in the bottom of the the "Mirror components" dialog. This option sets the initial status for mirroring.
Inventor
30.4.2012
8906×
this tip shared by ARKANCE experts applies to: Inventor ·
