CAD tip CAD tip # 7815:
Question
If your DesignCenter palette (Ctrl+2) in AutoCAD 2010, 2011, 2012, 2013, 2014, 2015 does not display the tab "DC Online", please check whether this tab is not disabled in the CAD Manager settings. It is off by default.
Run Start > Programs > Autodesk > CAD Manager Tools > CAD Manager utility (CMcontrol.exe) and on the "DesignCenter online" tab enable the "DC Online" functionality. Restart AutoCAD.
If you have not installed the CAD Manager utilities, install them from your AutoCAD installation media.
ACAD2015ACAD2011ACAD2010ADTACADMCivil
24.2.2011   18279×
this tip shared by ARKANCE experts applies to: AutoCAD 2015 · AutoCAD 2011 · AutoCAD 2010 · AutoCAD Architecture · AutoCAD Mechanical · Civil 3D ·
Tip 12753:"Local server is loading" when inserting a block in AutoCAD LT.
Tip 10173:How to insert a block from another DWG file?
Tip 7561:Find all DWG drawings with the given text in a block attribute.
Tip 7020:How to copy selected layers from another DWG file?
Tip 6212:How to transfer layers and blocks from one drawing to another?
Back    All CAD Tips
Categ:
Be.Smart T4R More info
