CAD tip CAD tip # 10249:
Question
One of the new features in the AutoCAD 2016 family is the new osnap mode "geometric center" (GCEN). This osnap returns cooridinates of the center of any closed line object (polyline). So you can easily draw connection lines between object centers, or draw centered labels in symbols, parcels, etc.
You can enable the geom. center mode through the status line icon, invoke it with the predicate GCEN, or preset it using the system variable OSMODE (bit-value 1024). Note the different osnap symbol (glyph) from the circle center osnap.
ACAD2016ACLT2016ADT2016Civil2016Plant2016
22.3.2015   19793×
this tip shared by ARKANCE experts applies to: AutoCAD 2016 · AutoCAD LT 2016 · AutoCAD Architecture 2016 · Civil 3D 2016 · AutoCAD Plant 3D 2016 ·
Tip 15090:3DPlot - 3D math surfaces in AutoCAD.
Tip 15089:2DPlot - parametric math curves in AutoCAD.
Tip 14967:The geometry cleanup tool for DWG drawings in AutoCAD 2027.
Tip 14942:How do I place specific types of entities on a specific DWG layer? (LAYER variables)
Tip 14898:AlignO - aligning selected entities in Corel style.
Back    All CAD Tips
Categ:
