Over 1.124.000 registered users (EN+CZ).
CAD tip # 7145:
Question
The utility CADstudio P2BLK converts (replaces) selected entities of the type POINT, CIRCLE or SHAPE to blocks (INSERT) of the given name.
The choosen block must be defined in the current DWG drawing. You can specify scale of the inserted blocks. Blocks are inserted to the same layer as the original objects. Possible block attributes are left at default values - later you can number the blocks e.g. using the InsertC/BlockC utility.
The P2BLK command inserts blocks to the reference points (centers) of the original entities.
The DELOBJ controls whether the source objects are deleted or not.
You can download the P2BLK application from
Download
You can preset the block insertion scale with the LISP variable _lastP2BLKscale:
(setq _lastP2BLKscale 2.0)You can preset the block name with the LISP variable _lastP2BLKname:
(setq _lastP2BLKname "MyBlock")
ACAD
6.1.2010
30739×
this tip shared by ARKANCE experts applies to: AutoCAD ·
