  Visitors: 7599
CAD tip CAD tip # 12136:
Security settings for Inventor data files and add-on applications.
A - answer Autodesk Inventor contains (just like AutoCAD) a couple of settings to ensure security of the CAD files and add-on applications, protection against viruses and other types of malicious code.
In general, it is recommended to install add-in applications only from reputable sources and, if possible, only those which are digitally signed.
Loading and running add-on applications can be individually controlled with the AddInLoadRules.xml configuration file - when deploying a network installation, you can have it automatically installed in the %INSTALLDIR%\Preferences\AddInLoadRules.xml folder - see its description and usage in the Inventor Help. You can also enable and block add-ons individually in the Add-in Manager (Tools > Options > Add-ins).
To protect against macros within CAD files (VBA and iLogic macros), it is advisable to set the iLogic security options - see Tools > Options > arrow > iLogic - Configuration > Security Options.
viruses and inventor
Enable checking the rules for any presence of malicious code, and define folders for which this checking will not be performed. You can also restrict automatic triggering of rules on events.
But before this, make sure these security antivirus settings will not disrupt any workflows in your existing enterprise automation tools.
Inventor
6.2.2019    11835×
Prices - CAD eShop:
applies to: Inventor ·
Tip 12330:Inventor reports the error "Failed to create folder" or "Error creating the lock file lockfile.lck"
Tip 11375:System error: The program can't start because mfc120u.dll is missing
Tip 10612:Revit error: Unable to open because of unresolved pointer references​
Tip 9656:Inventor: Cannot load library MbUI.dll and RxPart.dll.
Tip 9447:ActiveX Server returned an error: Error loading type library/DLL
VRMLout More info
