CAD tip CAD tip # 9818:
Question
The STEPOUT command in AutoCAD Mechanical offers several options for the STEP file export proces. You can access them through the "Options" button in the "STEPOUT translation" dialog.
An important option is the Units setting. It must match the size units used in your AutoCAD 3D DWG model, otherwise your model in the STEP-format file will be scaled up or down (larger or smaller than modelled).
ACADM
11.5.2014   17533×
this tip shared by ARKANCE experts applies to: ACADM ·
Tip 15090:3DPlot - 3D math surfaces in AutoCAD.
Tip 15089:2DPlot - parametric math curves in AutoCAD.
Tip 15065:AI rendering in Autodesk Forma Board.
Tip 15063:How do I convert the geometry of a Civil pipe network to 2D, or to SHP format?
Tip 14953:Importing ECLASS files into AutoCAD Electrical.
Back    All CAD Tips
Categ:
