Over 1.127.000 registered users (EN+CZ).
CAD tip # 9073:
Question
You can use two methods to publish 3D assemblies (IAM) from Inventor to stereolithografy (STL) files for 3D printing:
- Export: I > Export > CAD Format > type STL
- 3D print: I > Print > Send to 3D Print Service
Both methods generate identical STL files. In both cases you can set format, resolution (precision) and color support for the generated STL file.
The 3D print method also displays dimensions (volume) of the model in the selected scale. So you can estimate the price of the printed 3D model, or check the printability of the model on a given 3D printer.
Inventor2013
10.2.2013
19363×
this tip shared by ARKANCE experts applies to: Inventor 2013 ·
