CAD tip CAD tip # 9070:
Question
With the "Transfer Project Standards" tool you can transfer settings not only between two Revit projects but also from a Revit project to a Revit LT project.
Revit LT will ignore any settings that it does not support.
RevitRevitLT
9.2.2013   7025×
this tip shared by ARKANCE experts applies to: Revit · RevitLT ·
Tip 15045:Which cloud projects are available in the Autodesk Forma mobile app?
Tip 15040:Autodesk Flex Token Calculator - "Pay-as-you-go" pricing for licenses and services.
Tip 15032:Naming PDF files from Revit based on sheet number and sheet size.
Tip 14998:What is the difference between two open documents, two open Inventors, and two Inventors on two different PCs?
Tip 14993:Pay attention to Daylight savings time in Revit.
Back    All CAD Tips
Categ:
