CAD tip CAD tip # 6811:
Question
If you hear (in AutoCAD context) about files with the extension .vix, .isp, .dvg, .dvf, .sid, .dci, .dwi, .mni, .xig and other, it is most probably only a typo or misinterpreted character.
In these situations, such files are rather the .vlx (compiled LISP), .lsp (LISP), .dwg (drawing), .dwf (web drawing), .sld (slide), .dcl (dialog), .dwl (lock), .mnl (menu Lisp), .xlf (xref log) files.
Similarly with Inventor you may find changed characters in the IPT/LPT, IAM/LAM, IDW/LDW file extensions.
ACADACLTInv
23.7.2009   18082×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD LT · Inventor ·
Tip 14861:RegExpCnt - LISP string replace function with arithmetic/counter-extension
Tip 14858:How to work with railway data in XTR, NYL, TIT, or TRA formats in Civil 3D?
Tip 14833:CAD formats supported in Autodesk VRED 2026.
Tip 14310:Easy graphical display of the project or assembly file structure (hidden function).
Tip 13784:Export block coordinates to a table. How to use the DATAEXTRACTION command in AutoCAD LT?
Back    All CAD Tips
Categ:
