CAD tip CAD tip # 8008:
Question
The sketching application Autodesk SketchBook Designer 2012 (part of many "Design Suites") can draw freehand vector drawings (sketches) and store these drawings to many formats.
SketchBook can directly save the following file formats:
  • DWG (R14, 2000-2010)
  • PSD (incl. layers)
  • TIFF
  • PNG
  • BMP
  • JPG
  • PBM (portable bitmap)
  • TARGA
  • SVG
Directly saved DWG files are readable only with the SketchBook support. The contents of DWG files saved using the Export function are displayed in AutoCAD as spline curves and lines.
SketchBook
30.5.2011   14725×
this tip shared by ARKANCE experts applies to: SketchBook ·
Tip 9075:Missing edit grips on wipeouts.
Tip 8991:How to convert a DWG drawing to SVG?
Back    All CAD Tips
Categ:
