CAD tip CAD tip # 8429:
Question
The RENDER command, resp. the rendering parameters setting - RPREF, allows to set the maximum resolution of 4,096 x 4,096 pixels for the rendered scene.
ACAD
20.1.2012   8789×
this tip shared by ARKANCE experts applies to: AutoCAD ·
Tip 14999:How to add custom HDRI background (environment) for rendering in Fusion?
Tip 14349:12 free material texture libraries for PBR rendering.
Tip 13557:How to create an image with transparent background in Fusion 360?
Tip 13082:PDF published from AutoCAD shows blurred lines.
Tip 11790:How to get a hi-res image of an Inventor assembly (for a brochure, billboard...)?
Back    All CAD Tips
Categ:
