CAD tip CAD tip # 8012:
Question
When trying to PLOT a drawing, AutoCAD displays an error message: "The plotter configuration does not support the paper size of the current layout. What do you want to do?"
You are probably using a wrong print definition file .PC3 or its associated .PMP file. Either the file was copied from a different computer, from a different AutoCAD version, or it is pointing to a different printer driver. Try to re-create the PC3 file (and/or PMP).
ACAD
31.5.2011   18866×
this tip shared by ARKANCE experts applies to: AutoCAD ·
Tip 14826:AutoCAD runs slower on a laptop docked in a docking station.
Tip 14776:I cannot select duplex printing, copies or a specific printer tray in AutoCAD.
Tip 10759:How to publish a DWG to a PDF file without attaching "-Model" to its name?
Tip 10556:AutoCAD 2015 and 2016 do not allow to select paper size for Designjet T120/T520.
Tip 10461:Unattended DWG plotting and PDF publishing without AutoCAD.
Back    All CAD Tips
Categ:
